Any expert please help!
I have a problem replacing my CISCO878-K9 from the obsolete CISCO828. I can't copy and paste the exact configuration from CISCO828 to CISCO878-K9 to make it works.
This is the CISCO828 configuration:
Router#sh run Building configuration...
Current configuration : 807 bytes ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname Router ! boot-start-marker boot-end-marker ! ! no aaa new-model ip subnet-zero no ip routing ! ! ! ! interface Ethernet0 no ip address no ip route-cache bridge-group 1 hold-queue 100 out ! interface ATM0 no ip address no ip route-cache no atm ilmi-keepalive dsl equipment-type CPE dsl operating-mode GSHDSL symmetric annex A dsl linerate AUTO bridge-group 1 pvc 8/35 encapsulation aal5snap ! ! ip classless ip http server ! bridge 1 protocol ieee ! line con 0 transport preferred all transport output all stopbits 1 line vty 0 4 login transport preferred all transport input all transport output all ! scheduler max-task-time 5000 end
Router#
This is the default configuration on CISCO878-K9:
Current configuration : 3835 bytes ! version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname BOCC ! boot-start-marker boot-end-marker ! logging buffered 51200 warnings ! no aaa new-model ! resource policy ! ip subnet-zero ip cef no ip dhcp use vrf connected ip dhcp excluded-address 10.10.10.1 ! ip dhcp pool sdm-pool import all network 10.10.10.0 255.255.255.248 default-router 10.10.10.1 lease 0 2 ! ! no ip domain lookup ip domain name yourdomain.com ! ! crypto pki trustpoint TP-self-signed-1864134024 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-1864134024 revocation-check none rsakeypair TP-self-signed-1864134024 ! ! crypto pki certificate chain TP-self-signed-1864134024 certificate self-signed 01 3082024B 308201B4 A0030201 02020101 300D0609 2A864886 F70D0101
04050030 31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D
43657274 69666963 6174652D 31383634 31333430 3234301E 170D3032 30333031
30303037 32325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504
03132649 4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31
38363431 33343032 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030
81890281 8100F44C 68DCBED8 08D520A9 8F0C225F FE40E0D6 70E473CA C7BA2275
1E9F00B7 F9F58D8C B87BC1D4 7F455A72 4FCF1B93 6EE391B3 4F490546 5FE48E0C E7559208 83701703 405A017B C6F15982 F3A551D3 BD7111AA A5BED57F 4FCC2590 B3E57736 752BCC5C E6AC97E4 876E61B6 47D89695 8032F860 DB06642E F6E21834
027AC105 E3290203 010001A3 73307130 0F060355 1D130101 FF040530 030101FF
301E0603 551D1104 17301582 13424F43 432E796F 7572646F 6D61696E 2E636F6D
301F0603 551D2304 18301680 1459ED00 5C0CAF64 20529BC5 7A59541E FFB2A153 C4301D06 03551D0E 04160414 59ED005C 0CAF6420 529BC57A 59541EFF B2A153C4
300D0609 2A864886 F70D0101 04050003 81810049 00CFD008 259AA806 4CA7DA63 C9980E13 D5650226 CE20174A 296C927B 0F8D6AB4 45DB5011 AEC03F1F EC38D6F8 BDA3DDB9 D641C276 CE859A9B 048BAF97 9BF20C2F B342CB31 C7F338A1 A35AE815
316F9B97 D994FDCA 7F48866F F74F3317 B03074DF 33324777 BC2F443C 3912AF20
972BD24C 562632E1 3354D1B9 7CA24196 245DC8 quit username cisco privilege 15 secret 5 $1$N278$zqi7PtZedgdjt2FJKoKyJ/ ! ! controller DSL 0 line-term cpe ! ! ! ! interface BRI0 no ip address encapsulation hdlc shutdown ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$ ip address 10.10.10.1 255.255.255.248 ip tcp adjust-mss 1452 ! ip classless ! ip http server ip http access-class 23 ip http authentication local ip http secure-server ip http timeout-policy idle 60 life 86400 requests 10000 ! access-list 23 permit 10.10.10.0 0.0.0.7 no cdp run ! control-plane ! banner login ^C
----------------------------------------------------------------------- Cisco Router and Security Device Manager (SDM) is installed on this device. This feature requires the one-time use of the username "cisco" with the password "cisco". The default username and password have a privilege level of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI. Here are the Cisco IOS commands.
username privilege 15 secret 0 no username cisco
Replace and with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START GUIDE for your router or go to
BOCC#
Please help if anybody can provide me the sample configuration to fit in to CISCO878-K9 from my old CISCO828 configuration. Many thanks!
