CSS11000 doesn't respond on port 80 all else seems perfect
Mar 02, 2006 0 Replies
Hi all. I have a Cisco CSS11000 Load Balancer with a frustrating configuration issue.
It is currently balancing 2 MySQL servers perfectly with no issues. I am currently working on getting it to also balance 2 Apache servers, but I can't seem to get it working.
It responds on the circuit address I set up on the front end allowing telnet and FTP access to the actual LB. It will respond to pings on the VIP address I set up as well. I can get no response to HTTP requests on this VIP address though.
The LB can ping the Apache servers just fine, and even sends HTTP keep alives which show up in Apache's logs. Viewing the LBs web interface, shows both Apache servers as green.
I'm really at a loss here and would appreciate any suggestions.
Doug
The relevant portions of the config follow:
circuit VLAN30
ip address 10.99.99.1 255.255.255.0
circuit VLAN40
ip address 192.168.62.253 255.255.255.0
service hot-03 ip address 10.99.99.3 port 80 keepalive type http active
service hot-04 ip address 10.99.99.4 port 80 keepalive type http active
owner hot content mysite.mydomain.com add service hot-03 add service hot-04 vip address 192.168.62.250 port 80 protocol tcp balance aca active
owner hot-udp
content mysite.mydomain.com add service hot-03 add service hot-04 protocol udp vip address 192.168.62.250 port 80 balance aca active
