connecting to catalyst 2950
May 28, 2006 6 Replies
Jump to replies (6)
Hello,
I have in my net a catalyst 2950, and I want to create some vlans on it, but I cannot found it by IP. It's not on the DHCP server, what can I do?
Connect to it on the console port perhaps?
I dont have tried, now I dont have access to it with a laptop
well if you've never configured an ip address on it then you can't connect to it via IP (telnet) .
you'll have to connect to it at first with a cisco console cable (a light blue cable) and configure it that way .
Oh, I understand, but I must to use the cisco cable? or any serial cable works?
Specifically the Cisco roll-over console cable (light blue in color and flat, not round). That is unless you know the pinouts and make your own.
J
thanks for all, I'll buy one
J wrote:
