concentrator 3005
Feb 14, 2007 1 Replies
Does somebody know how you can Reset a cisco concentrator 3005 to factory default. I cannot connect to it so I have to do it manually. When I press the reset button on the backpanel nothing happens.
Hi David,
You may wish to investigate the Password Recovery Procedure for the Cisco VPN 3000 Series:
Hope this helps.
Brad Reese
