Concentrator 3000 and adding routes ?
Feb 24, 2008 5 Replies
Doan
Fromm the Configuration menu tree, drill down to System>IP Routing>Reverse Route Injection. Select the Network Extension Reverse Route Injection check box and click Apply. Doan
Hello all. I've got a vpn concentrator. Its management/private address is say:
172.16.16.115
I then have a local network:
192.168.1.x
I also have networks:
192.168.2.x 192.168.3.x - these are network outside of our building and connected to us through a VPN and its address for example is:
192.168.1.115
when I am connected through my cisco vpn I can ping 172.16.16.10 -
172.16.16.110 etc. I can also ping 192.168.1.10 - 192.168.1.110 etc...
I can not ping for example 192.168.2.10 or 192.168.2.110 or
192.168.3.10
Where and what would I add so that my cisco vpn knows thatany traffic for the 192.168.2.0 network needs to goto my other vpn device (192.168.1.115) I am guessing?
where is this added? thanks
Doan
OK I have done that and it makes no differance. I then added:
192.168.2.0/255.255.255.0 to the address pool Hold Down routes list. Still nothing, can not get to for example 192.168.2.10
If I do a traceroute to 192.168.2.10 from my local computer not connected through the vpn the trace goes to my local gatewy and then my nortel vpn router 192.168.1.173 and then from there it gets to
192.168.2.10
any ideas?
Route Injection.
In the groups config you are pointing to a network list. You need to edit that network list to include the additional subnets you wish to get to.
Yes I've done that, I have added: 192.168.2.0/0.0.0.255
did not do a th>
I take this as these networks are not LAN-to-LAN VPNs? If so, you can just add them as static routes on your concentrator.
Doan
