Hi
My work pc just got upgraded to cisco vpn klient 4.8 (from 4.2). And now the Windows xp stuff does not work. HTTP protocol goes fine though.
I get logged on to the network, but it does not run my login script. It takes aprox 30 min to get from boot/login to the desktop beein available.
And when you try to access any applications - it takes forever before it tells me that it does not work. It seems to me that everything maybe just takes forever and then times out????
My router is a Zyxel Zywall 1. It worked fine with VPN 4.2
I cant go back to old VPN client (work says no cause of security restrictions) - so I'm trying to find out what has changed - or what I must change in the router to make it work again.
Any ideas where to go?
regards Mette, Denmark
