Cisco soho 97 router web panel language change
Aug 17, 2005 4 Replies
Jump to replies (4)
Hi, I have obtained a Cisco soho 97 router.
All works fine, can use telnet and the console.
One small problem, the "web panel" is in japanese.
Any one have any idea how to convert/change it to english?
Or do I have to just reload an IOS onto it?
Thanks
snipped-for-privacy@gmail.com schrieb:
No, Cisco Router Web Setup resides on the 2MB webflash: only erase webflash: and load new CRWS files to webflash: Is independent of the IOS on flash:
But beware: the Soho9x IOS has much more features on CLI than the very limited CRWS interface.
For example you can configure this box even as a EZVPN server.
Uli Link schrieb:
Addition: "
Uli Link schrieb:
Addition to addition: this url doesn't work anymore :-( CRWS is obsoleted for quite a while, (but a brand new 64MB C836 came with CRWS factory installed ???) Contact me by mail if you'll need the CRWS files.
well it's a 2nd hand one, work were chucking it out so I decided to have it!
I shall mail you now!
Thanks, you have helped me before!
