Re: USB to Serial convertor
Jan 10, 2006 6 Replies
Jump to replies (6)
Hi Guys.
I am trying to use USB to serial console to Cisco 25xx, but i dont get anything back from the screen? When i used back the serial console, it works fine!. Any idea?
thx!
What is the make of the converter?
Not all converters will work but I know of the ones that have "Prolific" chipsets that work well. Have a look on Ebay there should be loads and some will mention support for break sequences that work for password recovey.
Hope this helps.
Rob
Are you using the correct com port?
Change Port Settings (change to COM1) or use other com port
Robetr
Hi Robert,
I did toggle between COM3 and COM4, i used both sCRT and Hyperterm, but still wouldnt work. thanks!
cheers, jk
Robert wrote:
You need to look to see what com port it is using. Can't just guess at it. It's in your device manager area listed under com ports.
Hi Brian,
ya, it is com3, but after trying a few times and even reinstalling the driver, but still, cant work.
cheers, jk
Brian V wrote:
