Cisco Secure 4.0
Jul 12, 2006 1 Replies
Is there a way of logging into a Cisco switch through Cisco Secure 4.0 and having it login into the telnet & enable mode at the same time?
I've worked at another place before and they had a tacacs sever set up so you could log into both telnet & enable mode at the same time. I know the tacacs server they were using wasn't a Cisco Secure sever so I would like to see if this is possible setting it up on a Cisco Secure Sever.
Thanks
yes there is - Via TACACS+ and enable privi level 15, Shell and Priv level
15 in the users setup page (Or grouplevel) HTH Martin Bilgrav
