Cisco AP1231 Telne timeout
Apr 28, 2005 4 Replies
Jump to replies (4)
Cisco AP1231 Telne timeout open original image
I am trying to do an extended debug on my APs and wish to keep a telnet session open for 5,6 hours at a crack. I have adjusted all the timeouts yet I still get disconnected after ten minutes. any thoughts? config follows fwiw ssh has the same results as telnet
thanks barry
begin 666 session.log M=F5R
"Barry Gross" wrote in message news:d4qkvu$g8k$ snipped-for-privacy@news.doit.wisc.edu... I am trying to do an extended debug on my APs and wish to keep a telnet session open for 5,6 hours at a crack. I have adjusted all the timeouts yet I still get disconnected after ten minutes. any thoughts? config follows fwiw ssh has the same results as telnet
thanks barry
version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec localtime show-timezone service password-encryption ! ! logging buffered informational ! clock timezone S -6 clock summer-time S recurring ip subnet-zero ! aaa new-model ! ! aaa authentication login default group tacacs+ enable aaa authentication login eap_methods group radius aaa authentication login mac_methods local aaa authorization exec default group tacacs+ aaa authorization configuration default group tacacs+ aaa accounting commands 0 default start-stop group tacacs+ aaa accounting commands 15 default start-stop group tacacs+ aaa accounting network acct_methods start-stop group radius aaa session-id common ! ! bridge irb ! ! interface Dot11Radio0 mac-address 0040.9657.2cec no ip address no ip route-cache ! encryption vlan 34 mode wep mandatory ! encryption vlan 345 mode wep mandatory ! encryption vlan 344 mode wep mandatory ! encryption vlan 343 mode wep mandatory ! encryption vlan 342 mode wep mandatory ! encryption vlan 341 mode wep mandatory ! ssid vlan346 vlan 346 authentication open ! ssid vlan344 vlan 344 authentication open eap eap_methods authentication network-eap eap_methods ! ssid vlan34 vlan 34 authentication open authentication network-eap eap_methods ! ssid vlan343 vlan 343 authentication open ! ssid vlan341 vlan 341 authentication open ! ssid vlan345 vlan 345 authentication open ! ssid vlan342 vlan 342 authentication open eap eap_methods authentication network-eap eap_methods ! speed basic-11.0 power local 50 no preamble-short channel 2412 station-role root fallback shutdown beacon dtim-period 10 no dot11 extension aironet no cdp enable ! interface Dot11Radio0.34 encapsulation dot1Q 34 native no ip route-cache no cdp enable bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding bridge-group 1 spanning-disabled ! interface Dot11Radio0.341 encapsulation dot1Q 341 no ip route-cache no cdp enable bridge-group 41 bridge-group 41 subscriber-loop-control bridge-group 41 block-unknown-source no bridge-group 41 source-learning no bridge-group 41 unicast-flooding bridge-group 41 spanning-disabled ! interface Dot11Radio0.342 encapsulation dot1Q 342 no ip route-cache no cdp enable bridge-group 42 bridge-group 42 subscriber-loop-control bridge-group 42 block-unknown-source no bridge-group 42 source-learning no bridge-group 42 unicast-flooding bridge-group 42 spanning-disabled ! interface Dot11Radio0.343 encapsulation dot1Q 343 no ip route-cache no cdp enable bridge-group 43 bridge-group 43 subscriber-loop-control bridge-group 43 block-unknown-source no bridge-group 43 source-learning no bridge-group 43 unicast-flooding bridge-group 43 spanning-disabled ! interface Dot11Radio0.344 encapsulation dot1Q 344 no ip route-cache no cdp enable bridge-group 44 bridge-group 44 subscriber-loop-control bridge-group 44 block-unknown-source no bridge-group 44 source-learning no bridge-group 44 unicast-flooding bridge-group 44 spanning-disabled ! interface Dot11Radio0.345 encapsulation dot1Q 345 no ip route-cache no cdp enable bridge-group 45 bridge-group 45 subscriber-loop-control bridge-group 45 block-unknown-source no bridge-group 45 source-learning no bridge-group 45 unicast-flooding bridge-group 45 spanning-disabled ! interface Dot11Radio0.346 encapsulation dot1Q 346 no ip route-cache no cdp enable bridge-group 46 bridge-group 46 subscriber-loop-control bridge-group 46 block-unknown-source no bridge-group 46 source-learning no bridge-group 46 unicast-flooding bridge-group 46 spanning-disabled ! interface FastEthernet0 no ip address no ip route-cache duplex auto speed auto ntp broadcast client no cdp enable ! interface FastEthernet0.34 encapsulation dot1Q 34 native no ip route-cache no cdp enable bridge-group 1 no bridge-group 1 source-learning bridge-group 1 spanning-disabled ! interface FastEthernet0.341 encapsulation dot1Q 341 no ip route-cache no cdp enable bridge-group 41 no bridge-group 41 source-learning bridge-group 41 spanning-disabled ! interface FastEthernet0.342 encapsulation dot1Q 342 no ip route-cache no cdp enable bridge-group 42 no bridge-group 42 source-learning bridge-group 42 spanning-disabled ! interface FastEthernet0.343 encapsulation dot1Q 343 no ip route-cache no cdp enable bridge-group 43 no bridge-group 43 source-learning bridge-group 43 spanning-disabled ! interface FastEthernet0.344 encapsulation dot1Q 344 no ip route-cache no cdp enable bridge-group 44 no bridge-group 44 source-learning bridge-group 44 spanning-disabled ! interface FastEthernet0.345 encapsulation dot1Q 345 no ip route-cache no cdp enable bridge-group 45 no bridge-group 45 source-learning bridge-group 45 spanning-disabled ! interface FastEthernet0.346 encapsulation dot1Q 346 no ip route-cache no cdp enable bridge-group 46 no bridge-group 46 source-learning bridge-group 46 spanning-disabled ! interface BVI1 ip address dhcp no ip route-cache ! ip http server ip http authentication aaa no ip http secure-server ip http help-path
radius source-interface BVI1 logging trap warnings logging facility local0 logging snmp-trap emergencies logging snmp-trap alerts logging snmp-trap critical logging snmp-trap errors logging snmp-trap warnings logging 10.101.1.183 snmp-server view basic iso included snmp-server view basic ieee802dot11 included snmp-server enable traps tty no cdp advertise-v2 no cdp run tacacs-server directed-request radius-server attribute 32 include-in-access-req format %h radius-server vsa send accounting bridge 1 route ip ! ! ! line con 0 session-timeout 35791 output terminal-type ansi transport preferred all transport output all stopbits 1 line vty 0 4 session-timeout 35791 output terminal-type ansi transport preferred all transport input all transport output all line vty 5 15 session-timeout 35791 output terminal-type ansi transport preferred all transport input all transport output all ! ntp clock-period 17189350 ntp server 10.101.1.6 end
~ I am trying to do an extended debug on my APs and wish to keep a telnet ~ session open for 5,6 hours at a crack. I have adjusted all the timeouts
Not *all* of them ...
~ yet ~ I still get disconnected after ten minutes. any thoughts? config follows ~ fwiw ssh has the same results as telnet ~ ~ ~ thanks ~ barry ~ ~ version 12.3
[ irrelevant config bits elided ]
~ line vty 0 4 ~ session-timeout 35791 output ~ terminal-type ansi ~ transport preferred all ~ transport input all ~ transport output all ~ line vty 5 15 ~ session-timeout 35791 output ~ terminal-type ansi ~ transport preferred all ~ transport input all ~ transport output all
Try mixing in: "exec-timeout "
Aaron
Another point ... if you are trying to collect debug output across your IOS devices across a long period of time ... here are some alternatives:
- set up a syslog server and log your messages to it
- configure "logging buffered debugging", where is some value that is large enough to capture all the debugging messages of interest before the buffer wraps, yet is comfortably smaller than your available free processor memory. Then suck out the buffer contents with: undebug all / terminal length 0 Then either "show log" to a captured terminal session, or use "show log | redirect "
Aaron
