Login to serial console on my cat 4000 running CatOS - telnet passwords don't work.
Jun 21, 2007 0 Replies
I can telnet into the switch just fine. I know the passwords. When I connect to the console port by way of a serial cable, I get the "User Access Verification" and "Password:" prompt. It won't accept my login or enable passwords. Is there another setting needed to allow login from the console port?
Here's some info. cat4000 (enable) sho authen
Login Authentication: Console Session Telnet Session Http Session
---------------- tacacs disabled disabled disabled radius disabled disabled disabled kerberos disabled disabled disabled local enabled(primary) enabled(primary) enabled(primary) attempt limit 3 3 - lockout timeout (sec) disabled disabled -
Enable Authentication: Console Session Telnet Session Http Session
---------------- tacacs disabled disabled disabled radius disabled disabled disabled kerberos disabled disabled disabled local enabled(primary) enabled(primary) enabled(primary) attempt limit 3 3 - lockout timeout (sec) disabled disabled - cat4000 (enable)
Am I missing something?
Thanks for any and all help and advice. Dave
