Cisco Monitoring Software
Nov 29, 2005 2 Replies
Cisco Monitoring Software open original image
Hello all,
I am looking for some Cisco monitoring software. I need to monitor approximately 40 devices (Cisco Access Points, 2950's, 4500 series, and a few other devices). I need this software to provide trending information, and hopefully reports that I can generate (previous day, week, month, yearly trending). I would like to find a piece of software that is relatively cheap. I have heard that Cisco Works Small Network Management Solution would be a good software package to have, but I didn't know if there was anything better out there. Does anyone know of any software that might be sufficient to these needs?
Thanks, Adam
MRTG/RRD solution may fit your bill. It's free and works well.
Others that come to mind are:
1) What's Up Gold (commercial package) 2) Opennms.org 3)
And numerous others.
Hallo Adan,
i'm using ZABBIX
and are very satisfied with it. You can generate graphs, reports, set triggers and actions...
The most exiting thing for me at least is that i can integrate external scripts as well and store the resulting values also inside ZABBIX.
I have used MRTG for years and now change to ZABBIX.
Regards Thomas
-------- Original Message -------- Subject: Cisco Monitoring Software (29-Nov-2005 21:02) From: UVAHOOS To: comp.dcom.sys.cisco
