Cisco J1 or J2 antenna connector
Jan 17, 2006 2 Replies
Most relevant reply
CiscoHeadsetAdapter.com
If you have only one antena, you should plug it to J1 connector. If you have two antenas (or two cables from one antena) - use both connectors. In case of one antena connector you should specify in the configuration that you use one connector. Good luck, Mike
If I am installing a Cisco 350 air card does it matter if I plug the external antenna into the J1 or J2 connector? It does not seem to....
Thanks
Good luck,
Mike
snipped-for-privacy@gmail.com schrieb:
...make any difference, as long as the card uses antenna diversity. The card automatically selects the better port, which usually is the one with an antenna connected ;-)
You can also select an antenna port for RX and TX. The terms "left" and "right" are a little misleading, as you can look onto your card from different directions. Sometimes "left" and "right" are referred as "primary" and "secondary". J1 is "primary".
