PC card with antenna connector
Feb 23, 2006 2 Replies
I'm looking for a good, preferably low cost, currently manufactured PCMCIA card for 802.11B/G wireless LAN use that has an external antenna connector and will display signal and noise level dBm on the setup screen. Please list all known - -
Thanks
Chuck
Have you tried Google? It is, after all, "your friend."
I have a compex cpx.com with one - think it was discontinued though. For the notebook I now use a HawkingTech with the flip&twist panel antenna -fwiw - Works a multitude better than cpx with a blade antenna.
