cisco DSLAM output
Nov 08, 2005 0 Replies
Can anyone suggest a source for what these outputs are in plain English? I have already done Google searches, dug through thecisco site and read End to End DSL Architectures with no luck.
ADSL Chipset Self-Test: Alarms: Alarms Enabled: ATM Statistics: ATM Payload Scrambling: Attainable Aggregate: Card status: Check Bytes (FEC): Circuit ID: CO Modem Firmware Version: Corrected Superframes: CPE Info: DSL Statistics: DMT Profile Name: ES Events: Far End LPR Events: Fast Path: Init Events: Interleave Path: Interleaving Delay: IOS admin: Last Change: Line Status: Link Traps Enabled: LOS Events: At the physical layer, the number of times the DSLAM (ATU-C) has lost contact with the modem (ATU-R). LOF/RFI Events: Margin: Minrate blocking: No. of changes: oper: Overhead Framing: Operating Mode: Port Status: R-S Codeword Size: Received Superframes: SNR Monitoring: Subscriber Name: Test Mode: Trellis Coding: Training Mode: Transmitted Superframes: Uncorrected Superframes: Version Number: Vendor ID:
