ATM AIM AND LUCENT PSAX 3200
Sep 24, 2005 4 Replies
Jump to replies (4)
ATM AIM AND LUCENT PSAX 3200 open original image
I work for an ISP and i'm trying to bring up a IMA group with a CISCO AIM series and a Lucent PSAX IMA CARD. I've done this plenty of times before with regular non AIM routers but I'm having a little problem now.
Little PROBLEM:
-I'm testing Layer 2/Layer 3 with a Redback and i'm getting accross with the occassional packet loss.
-When I debug for some reason i'm getting an "ima group up/down messages".
-I'm also getting an error saying "ATM not active yet"
At the Lucent side, i'm getting cell mismatch errors like crazy but the ima group never drops.
Any input would be awesome! Thanks.
It seems per the description of your post that the AIM is not participating in the clock, can you confirm this? besides do you have any clocking errors? slips? etc? Hope this helps.
You may wish to investigate Cisco's Configuring Multiport T1/E1 ATM Network Modules with IMA:
Sincerely,
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272
Thanks for the info, but still getting the following errors: atmcisco#debug atm errors ATM errors debugging is on atmcisco#term mon atmcisco#
*Sep 25 19:45:13.259: ATM(ATM0/2/0): ATM not active yet *Sep 25 19:45:15.259: ATM(ATM0/2/0): ATM not active yet *Sep 25 19:45:17.259: ATM(ATM0/2/0): ATM not active yet
atmcisco#debug atm events ATM events debugging is on atmcisco#term mon atmcisco#
*Sep 25 19:45:42.955: atm_aim_uni_reset ATM0/2/0 *Sep 25 19:45:43.115: atm_aim_uni_reset ATM0/2/1
atmcisco#debug ima IMA network interface debugging is on atmcisco#
*Sep 25 19:49:41.615: %LINK-3-UPDOWN: Interface ATM0/IMA2, changed state to down *Sep 25 19:49:43.631: %LINK-3-UPDOWN: Interface ATM0/IMA2, changed state to up
** HERE IS MY CONFIG
atmcisco#show run Building configuration...
Current configuration : 2139 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname atmcisco ! boot-start-marker boot system flash c2800nm-spservicesk9-mz.123-14.T4.bin boot-end-marker ! no logging console
! no aaa new-model ! resource policy ! network-clock-participate wic 2 no network-clock-participate wic 3 network-clock-participate aim 1 network-clock-select 1 T1 0/2/0 network-clock-select 2 T1 0/2/1 ip subnet-zero ! ! no ip cef no ip dhcp use vrf connected ! ! no ip domain lookup no ftp-server write-enable ! ! !
! controller T1 0/2/0 mode atm aim 1 framing esf clock source line primary linecode b8zs cablelength short 133 ! controller T1 0/2/1 mode atm aim 1 framing esf linecode b8zs cablelength short 133 ! controller T1 0/3/0 mode atm aim 1 framing esf linecode b8zs ! controller T1 0/3/1 mode atm aim 1 framing esf linecode b8zs ! ! ! interface FastEthernet0/0 ip address duplex full speed 100 ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface ATM0/IMA2 ip address 10.30.1.1 255.255.255.252 atm uni-version 3.0 no atm auto-configuration no atm ilmi-keepalive no atm address-registration no atm ilmi-enable pvc 1/69 ! ! interface Serial0/0/0 no ip address shutdown no fair-queue ! interface Serial0/1/0 no ip address shutdown ! interface ATM0/2/0 no ip address scrambling-payload ima-group 2 atm uni-version 3.0 no atm ilmi-keepalive ! interface ATM0/2/1 no ip address scrambling-payload ima-group 2 atm uni-version 3.0 no atm ilmi-keepalive ! interface ATM0/3/0 no ip address shutdown no scrambling-payload no atm ilmi-keepalive ! interface ATM0/3/1 no ip address shutdown no scrambling-payload no atm ilmi-keepalive ! ip classless ip route 0.0.0.0 0.0.0.0 10.30.1.2 ! ! ip http server no ip http secure-server ! ! ! ! control-plane ! ! ! ! ! ! !
**AT this point im telling the cisco router to
-Pull the clocking from the psax (t1 0/2/0 the primary source for clocking)
-AIM1 and WIC 2 are participating in the "network clocking".
***THESE ARE THE MISMATCHED CELLS ON THE PSAX3200 THE 2 IMA ATM PORTS ARE CONFIGURED THE FOLLOWING WAY: ((NOTICE THE LOCAL TIMING ))
DS1 IMA Port and Channel Configuration [MIAMI]
_Slot: 11__Port: 01__[Channel: 001]_______Channel Configuration________________ | Line Type....... Esf | Interface Type..... AtmIma [Line Coding]... B8zs | Cell Scramble...... Enabled Loopback........ NoLoop | [Admin Status]..... InService Transmit Clock.. LocalTiming | [Oper Status]...... InService Line Build Out.. UpTo133Feet | | [Line Status]... NoAlarm | |
|_______________________________________ | | Apply Port Configuration | Reset Port Display | Take Interface Out Of Service | | Configure Interface ->
| View Port Statistics ->
| | Go Back to Card Configuration
_______________________________________|_______________________________________
****ON THE BACK END IM GETTING
ATM IMA Interface Configuration [MIAMI] _Slot: 11__Port: 02__Channel: 001________Interface Statistics________________ | [Admin Status].. InService | [IMA Violations].........
36568 [Oper Status]... InService | [OIF Anomalies].......... 0 | [Near-end Tx Failures]... 0 Link States | [Near-end Rx Failures]... 0 [Near-end Tx]... Usable | [Far-end Tx Failures].... 0 [Far-end Tx].... NotInGroup | [Far-end Rx Failures].... 0 [Near-end Rx]... UnusableFailed | [Tx Stuffs].............. 164 [Far-end Rx].... NotInGroup | [Rx Stuffs].............. 0 | [Time Elapsed]........... 0:01:33 Defects | [Near-end Rx]... Lif | [Far-end Rx].... NoDefect | | | Continuous Update Update Display | Reset Statistics Take Interface Out Of Service |_____________________________________ Delete Interface and Return -> | | Go Back to Port Configuration
****MY IMA CONFIGS IS THE FOLLOWING
DS1 IMA Group Configuration [MIAMI]
_Slot: 11__Port: 07____Channel:
001____________________________________________ | Minimum Tx Links.... 1 | Interface Type.... AtmUni3-0 Minimum Rx Links.... 1 | [Admin Status].... InService Near-end Tx Clock... Ctc | [Oper Status]..... InService Tx IMA Id........... 128 | Tx Frame Length..... M128 | [Near-end State].. Operational Link Delay Diff..... 25 ms | [Far-end State]... Operational Compatibility Mode.. Yes | [Failure Status].. NoFailure Alpha Value......... 2 cells | [Group Symmetry].. SymOperation Beta Value.......... 2 cells |_______________________________________ Gamma Value......... 1 cells | Apply IMA Group Configuration Ports In The Group.. 1 2 | Reset IMA Group Display Ports Available..... 3 4 5 6 | Take Interface Out of Service | [Far-end Tx Clock].. Ctc | Configure Interface -> [Rx IMA Id]......... 35 | View IMA Group Statistics -> [Rx Frame Length]... M128 | [Least Delay Link].. Port 1 | [Max Delay Diff].... 1 ms | Go Back to Channel Config ->
** ON THE BACK END...
ATM UNI Interface Statistics [MIAMI]
_______________________________________________________________________________
[Valid Cells Rcvd]....... 6.6549 e6 [Errored Cells Rcvd]..... 0000000023 [Mismatched Cells Rcvd].. 0003959127 [Valid Cells Sent]....... 8.0330 e3 [Null Cells Sent]........ 6.6432 e6 [Time Elapsed]........... 0:33:39
At this point I don't think it's a timing issue, am I missing something here?
wrote:
You may wish to investigate Cisco TAC Case K16466674.
ATM Advanced Integration Module (AIM) modules installed in
2600/3600/3700 routers require some unique clocking configuration to allow it to function properly. Failure to configure it properly results in errors on the T1/E1 controller and Inverse Multiplexing (IMA) links, as well as groups that flap continuously.
http://129.41.16.73/atm/showcase?case=K16466674 Brad Reese Worldwide Cisco Repair
