2801 two DSL multilink throughput problem..
Sep 12, 2006 0 Replies
I just installed a shiny new 2801 with two WIC1-ADSL's .. for a client that has TWO ADSL connects. (I'm in Canada, both are PPPoE)
My ISP claims to have done this config before -- without any problems, so I think they're thinking the problem is somewhere in my config (below).
My goals for the config are to get their throughput to nearly double, while increasing reliability. There's no need to prioritize any traffic based on type. It's a small shop (dozen seats)..
Here's the output from SH-RUN. If you want anything more detailed, just let me know..
Best, .. Scott!
Building configuration...
Current configuration : 2369 bytes ! ! Last configuration change at 23:38:53 EST Sun Sep 10 2006 by sdavis ! NVRAM config last updated at 23:38:55 EST Sun Sep 10 2006 by sdavis ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname NG2800 ! boot-start-marker boot-end-marker ! logging buffered 51200 warnings enable password 7 05130B5F2C4D560C1529 ! aaa new-model ! ! aaa authentication login default local aaa authentication ppp default local ! aaa session-id common ! resource policy ! clock timezone EST -5 mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ip subnet-zero ip cef ! ! no ip dhcp use vrf connected ! ! ip domain name northgate.local ip name-server 66.207.192.4 vpdn enable vpdn ip udp ignore checksum ! ! username MUNGED privilege 15 secret 5 MUNGED ! ! ! interface FastEthernet0/0 description Fast0/0.. ip address MUNGED 255.255.255.248 no ip mroute-cache duplex auto speed auto ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface ATM0/1/0 no ip address no ip mroute-cache no atm ilmi-keepalive dsl operating-mode auto ! interface ATM0/1/0.1 point-to-point description DSL WIC1 pvc 0/35 pppoe-client dial-pool-number 200 ! ! interface ATM0/3/0 no ip address no ip mroute-cache no atm ilmi-keepalive dsl operating-mode auto ! interface ATM0/3/0.1 point-to-point description DSL WIC3 pvc 0/35 pppoe-client dial-pool-number 200 ! ! interface Dialer200 bandwidth 99999 ip address negotiated ip mtu 1492 encapsulation ppp dialer pool 200 dialer idle-timeout 0 dialer load-threshold 1 either dialer persistent dialer-group 1 ppp authentication pap callin ppp pap sent-username snipped-for-privacy@MungedISP.com password 7 MUNGED ppp multilink ppp multilink load-threshold 1 either ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer200 ! ip http server ip http access-class 23 ip http authentication local ip http timeout-policy idle 60 life 86400 requests 10000 ! dialer-list 1 protocol ip permit ! control-plane ! ! line con 0 speed 38400 line aux 0 line vty 0 4 access-class 23 in privilege level 15 transport input telnet line vty 5 15 access-class 23 in privilege level 15 transport input telnet ! ntp clock-period 17208142 ntp source Dialer200 ntp server 128.100.56.135 end
NG2800#
