cisco => Allied telesyn
Jul 02, 2007 1 Replies
from the aux or console port of the cisco can I connect into the console line of the allied telesyn? this will allow a user to telnet to one router and then access the other.
There is no async on the cisco, there is one on the allied.
Flamer.
ha scritto nel messaggio news: snipped-for-privacy@g37g2000prf.googlegroups.com...
Yes, you usually can use your Cisco aux port to connect to another low speed serial port by reverse telnet.
Regards, Gabriele
