Cisco 876 - Filtered VPNs
Sep 27, 2006 2 Replies
Hello,
I set up an VPN Server on a Cisco 876 and the Access with the Cisco VPN Client works well. The ACL on the Dialer Interface permits VPN Protocol data. And now the Question: The traffic *inside* the VPN tunnel should be restricted. For eg. a VPN User should only have access to HTTP on a server directly connected to the Cisco. How are filtered VPNs created with Cisco VPN technology ?
Georg Dingler schrieb:
crypto map cmap 10 ipsec-isakmp set ip access-group 111 in set ip access-group 112 out
Thank you very much ! Meanwhile I discoverd the same feature via SDM Manager (VPN Components -> IPSec -> IPSec Policy -> IPSec Rule).
Uli Link schrieb:
