Cisco VPN Client - client-LAN access for headquarter
Apr 01, 2009 2 Replies
Hello everybody,
I understand that the VPN Client=B4s "local LAN access" feature enables the Client to also access ressources in it=B4s own LAN - which works fine in my setup. Having the feature activated I can see my local LAN routes and the secured routes in the VPN Client statistics.
My question is:
How is it possible for a computer in the headquarter behind the VPN Concentrator (which is a Cisco router) to access the resources (e.g. printer) in the client-LAN?
Right now I can only ping the client computer=B4s tunnel-IP-address, but not the address of the client=B4s LAN-NIC or the printer.
I played with static routes on my VPN concentrator, but could not achieve the access to the client=DFs LAN from a computer in my headquarter.
Is that possible at all with the Cisco VPN client?
Thank you for any hint.
Mathias
Maybe I should add, that I activated routing on the Windows XP client PC (\\HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\Tcpip \\Parameters\\IPEnableRouter=3D1).
It doesn=B4t help yet...
Mathias
mgummert schrieb:
LPD/LPR sharing of the printer on the client?
That's expected.
No. You can use a small Cisco IOS router setup in network extension mode as VPN client.
