Cisco 871 : NAT virtual interface
May 16, 2006 1 Replies
Cisco 871 :  NAT virtual interface open original image
According to this:
  1. enable
  2. configure terminal
  3. interface type number
  4. ip nat enable
  5. exit
  6. ip nat pool name start-ip end-ip netmask netmask add-route
  7. ip nat source list access-list- number pool name vrf name
  8. ip nat source list access-list- number pool name vrf name overload
should do the trick. But I don't have a vrf spaciffied which is a problem when it comes to step 7.
How can I specify a correct vrf?
What I'm trying to do. Make nat work on FastErthernet other then F4. So I added a new vlan. Added f0 to new vlan. And configured a vlan interface (vlan 2).
THX in advance, M
you need a better image... use the ios feature navigator to figure out which image for
871 supports this config...
google "ios feature navigator"
