Cisco 3620 VPN not listening UDP 500 / 4500
Jul 30, 2005 1 Replies
My Cisco 3620 IOS router is not listening on ports 500 and 4500 to setup the VPN connection. what could be wrong with my config?
acc01# sh ip sockets Proto Remote Port Local Port In Out Stat TTY OutputIF 17 0.0.0.0 0 xxx 67 0 0 2211 0 17 --listen-- xxx 123 0 0 1 0 17 --listen-- xxx 161 0 0 1 0 17 --listen-- xxx 162 0 0 11 0 17 --listen-- xxx 56636 0 0 1 0
! version 12.3 service timestamps debug datetime localtime service timestamps log datetime localtime service password-encryption ! hostname xxx ! boot-start-marker boot-end-marker ! logging buffered 8096 debugging enable password xxx ! username console password xxx clock timezone GMT 1 clock summer-time GMT+01:00 recurring last Sun Mar 2:00 last Sun Oct 3:00 no aaa new-model ip subnet-zero no ip source-route ! ! no ip cef ip domain name xxx ip name-server xxx ip name-server xxx ! ip audit po max-events 100 ! isdn switch-type basic-net3 ! ! crypto isakmp policy 3 encr 3des authentication pre-share group 2 ! crypto isakmp policy 20 encr 3des authentication pre-share group 2 ! crypto isakmp client configuration group management key mykey dns xxx pool vpn_pool acl 100 ! ! crypto ipsec transform-set ip2encr esp-3des esp-md5-hmac ! crypto dynamic-map dynmap 40 set transform-set ip2encr ! ! crypto map ip2 client authentication list userauthen crypto map ip2 isakmp authorization list groupauthor crypto map ip2 client configuration address respond crypto map ip2 40 ipsec-isakmp dynamic dynmap ! ! ! ! interface FastEthernet0/0 ip address xxx 255.255.255.192 ip nat outside duplex auto speed auto no cdp enable crypto map ip2 ! interface FastEthernet0/1 ip address 10.1.0.254 255.255.0.0 ip nat inside duplex auto speed auto no cdp enable ! interface BRI1/0 no ip address isdn switch-type basic-net3 no cdp enable ! interface BRI1/1 no ip address shutdown isdn switch-type basic-net3 no cdp enable ! interface BRI1/2 no ip address shutdown isdn switch-type basic-net3 no cdp enable ! interface BRI1/3 no ip address shutdown isdn switch-type basic-net3 no cdp enable ! interface Group-Async1 ip address negotiated encapsulation ppp async mode interactive peer default ip address pool setup_pool ppp authentication chap pap group-range 1 2 ! ip local pool setup_pool 10.1.0.100 10.1.0.199 ip local pool vpn_pool 10.2.0.0 10.2.0.100 ip nat inside source route-map nonat interface FastEthernet0/0 overload no ip http server no ip http secure-server ip classless ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 ! ! access-list 1 permit 10.0.0.0 0.255.255.255 access-list 100 permit ip 10.1.0.0 0.0.255.255 10.2.0.0 0.0.255.255 access-list 101 deny ip 10.1.0.0 0.0.255.255 10.2.0.0 0.0.255.255 access-list 101 permit ip 10.1.0.0 0.0.255.255 any dialer-list 1 protocol ip permit no cdp run ! route-map nonat permit 10 match ip address 101 ! ! line con 0 line 1 2 login local modem Dialin autoselect during-login autoselect ppp stopbits 1 speed 115200 flowcontrol hardware line aux 0 line vty 0 4 password xxx login line vty 5 password xxx login ! end
Did you ever try to connect using the vpn clients. Secondlh you have used:
But I dont see any equivalent aaa commans in the router config. aaa new-model
Go to cisco.com and search for a sample c> My Cisco 3620 IOS router is not listening on ports 500 and 4500 to setup
