cisco 828 flash file
Aug 12, 2005 3 Replies
Jump to replies (3)
sajjad shamsi schrieb:
load an IOS image from rommon and the router should start again.
If someone erased the flash file, is any other option to get back router on Router prompt istead of rommon one. regards
On the boot press the break key :
Use the tftpdnld command it erases all existing data in Flash memory before downloading a new software image to the router , but it isn't a problem in your state .
For the reference of this command see :
Best regards
Rocco
Thanks your help but how I load an IOS image there is any instruction and or bat file.
