Cisco 803 bridge
Apr 09, 2006 0 Replies
Hi I have two networks in two locations connectoe throug isbd line with cisco 803. The configuration works properly and I able to establish connection between two locations and ping machines which are in both networks. I want to set up cisco routers so the computers in location A can access internet through isdn connection to cisco 803 in location B which is connected to unix router with internet access.
B isdn B ethernet cisco803 ------------------cisco803
----------------unix_router-------INTERNET
Should I use isdn bridge with cisco in location B is it possible with cisco 803 ? Should I use some ip static route entries ?
TIA
