Cisco 3620 and OSPF for IPv6 not working !
Sep 08, 2005 3 Replies
Jump to replies (3)
After various tests using OSPFv3 for IPv6 routing in Cisco1721's with success, i'm now trying to reorganize our IPv6 network centralizing the routing in one Cisco3620 (IOS C3620-IS-M, Version 12.3(15a)).
The IPv6 works well in this router/IOS (supporting at this moment ~32VLANs with IPv6), the only *BIG* problem I've found is that a can't instantiate the OSPFv3 process to extend the IPv6 to other areas of the network served by another router.
When I type:
C3620-WILE(config)#ipv6 router ospf ? Process ID
C3620-WILE(config)#ipv6 router ospf 2 C3620-WILE(config)#
The command exists (the CLI does inline expansion of the command and gives help information about it), but executing-it doesn't switch the context as it does with OSPF/IPv4
C3620-WILE(config)#router ospf 1 C3620-WILE(config-router)#
Does anyone know anything about this ?? Is there some magic trick to use OSPFv3 in this platform ?
TIA.
Symptoms: OSPFv3 neighbors may not come up when IPv6 IPSec is configured.
Conditions: This symptom is observed on a Cisco router that has more than one interface configured for OSPFv3 and IPv6 IPSec.
Workaround: Disable IPSec for IPv6 or configure only a single interface on the router for IPv6 IPSec.
Sincerely,
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272
Thanks for the tip anyway, but the case isn't that, I'm not using IPSec, that's a really plain dual stack IPv6/IPv4 deployment.
The router is already running another process of OSPF for IPv4 can that be the problem ?? In the C1721 the configuration was very similar (probably only interface naming changed) and as I said it worked perfectly. I'm using the switch module in the 3620 (NM-16ESW) could that have some interference with OSPF ?
There are requirements for the NM-16ESW.
Software and memory requirements:
Brad Reese
