3750 SMI and EMI images?
Nov 15, 2005 2 Replies
Wayne
Odds are you only *need* the SMI Version (now called IP Base). Are you using the 3750's for their routing functionality? EMI (now called IP Services, I think?) includes routing protocols, BGP, EIGRP, OSPF and other acronyms.
Hi all,
Would someone mind clarifying how the SMI and EMI images work on 3750 switches? I have read the following in the 3750 software installation guide:
The Catalyst 3750 switches are shipped with either of these software images installed:
=B7 Standard multilayer image (SMI), which provides Layer 2+ features (enterprise-class intelligent services). These features include access control lists (ACLs), quality of service (QoS), static routing, and the Hot Standby Router Protocol (HSRP) and the Routing Information Protocol (RIP). Switches with the SMI installed can be upgraded to the EMI.
=B7 Enhanced multilayer image (EMI), which provides a richer set of enterprise-class intelligent services. It includes all SMI features plus full Layer 3 routing (IP unicast routing, IP multicast routing, and fallback bridging). To distinguish it from the Layer 2+ static routing and RIP, the EMI includes protocols such as the Enhanced Interior Gateway Routing Protocol (EIGRP) and the Open Shortest Path First (OSPF) Protocol.
We have been purchasing both EMI and SMI switches for use in the same stack. We have been using the "arc copy-sw" command to synchronise IOS versions across the switches.
Does this mean we have been copying EMI images onto SMI switches? Or vice versa? Am I confusing images with IOS versions? Are they the same thing?
Many thanks,
Paul
hi paul,
if you use the EMI or the SMI the hardware is always the same - so you can use both software. but you have to use the the same software on stack-member-groups.
so if you use the "archive copy-sw" command you put the software from the device you are typing the command - to other switches within the stack-member-group. you should know if this software is EMI or SMI, because all other switches runn after reload this software.
bye, /martin
schrieb im Newsbeitrag news: snipped-for-privacy@f14g2000cwb.googlegroups.com... Hi all,
· Standard multilayer image (SMI), which provides Layer 2+ features (enterprise-class intelligent services). These features include access control lists (ACLs), quality of service (QoS), static routing, and the Hot Standby Router Protocol (HSRP) and the Routing Information Protocol (RIP). Switches with the SMI installed can be upgraded to the EMI. · Enhanced multilayer image (EMI), which provides a richer set of enterprise-class intelligent services. It includes all SMI features plus full Layer 3 routing (IP unicast routing, IP multicast routing, and fallback bridging). To distinguish it from the Layer 2+ static routing and RIP, the EMI includes protocols such as the Enhanced Interior Gateway Routing Protocol (EIGRP) and the Open Shortest Path First (OSPF) Protocol.
Many thanks,
Paul
