cisco 1811
Sep 12, 2007 1 Replies
cisco 1811 open original image
Using the SDM, I set up the cisco 1811 FE0 to connect to a static IP and got it setujp with the iP and mask, where do I set set the DNS?
I tried to follow the instruction from the test conneciton result, but I dont get it:. I think there is an DNS problem
Go to 'Configure->Interfaces and Connections->Edit Interface & Connection' and change the encapsulation. 2. If this is an unencapsulated interface, verify that the cable is properly connected. Retest connection.
The error was for for no configured DNS
I have never used the SDM, but dns is a global command and will be set on the device as a whole, not just an interface. Try to look at the more generic settings menus.
Here is a comprehensive guide:
