port flapping
Nov 29, 2005 2 Replies
I 've got a problem with Catalyst 2980G. Ports on it have been flapping. This problem concern only one switch in my network only one vlan. There are no errors on this ports, it seems like broadcast or unicast is flooding but I don't know how to fix it.
Set a syslog server
is widely used under windows) and have the switch send its logs to it. It will give you plenty of information and you'll be able to troubleshoot more easily.
WHat kind of flapping? If the port is going down and up then I would chaeck that PC for virus/spyware. Each time we have a port doing this it is because of an infected PC that is scanning every IP in existence as fast as it can.
If it is MAC address flapping between two ports, you may have a multi-nic server that needs etherchannel support from the switch.
If macs are flappiing between cross-over/trunks you may have some kind of loop or repeated fail-over. DiGiTAL_ViNYL (no email)
