Cisco 1800 dot11radio0
Mar 28, 2008 22 Replies
IIS-R1#sh run int dot11radio0 Building configuration...
Current configuration : 335 bytes ! interface Dot11Radio0 ip address 192.168.254.1 255.255.255.252 ! encryption mode ciphers tkip ! ssid IIS ! speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 channel 2422 station-role root antenna receive right antenna transmit right end
================================================================= IIS-R0#sh run int dot11radio0 Building configuration...
Current configuration : 259 bytes ! interface Dot11Radio0 ip address 192.168.254.2 255.255.255.252 ! encryption mode ciphers tkip ! ssid IIS ! speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0 station-role non-root antenna receive right antenna transmit right end
Well one test that you might want to try is to reverse the station roles and see if the problem follows.
Thats an interesting idea. It hasnt crashed in over a week. Maybe this weekend I can go in and make those changes...
