cisco 17xx or 851
Dec 23, 2005 6 Replies
Jump to replies (6)
cisco 17xx or 851 open original image
Hello I have a pix in the main office and crypto maps (3des ) to all my remote locations.currently all my remote locations have 17xx routers with 2 ethernet cards, one built in and a wic ether card. In China and HK i set up a spoke and hub config. With one subnet in China, One subnet in HK and 3 subnets here in the main office. I found the 851 and 107 router to be really cheap. Looks like 107 can do only dsl. My remote office use dsl or cable with a static ip. Are there any disavantages of using a 851 instead of a 1700? can 851 use 3des crypto maps? spoke and hub with access-lists? What about the 107s? thanks.
for got to ask also does 851 have ip helper, what ios does it run?
The 1700 supports hardware encryption, whereas the 800s don't. I have a 871 router for home use and am quite happy with it--it supports about 10 Mbps clear text and around 3 for encryption, which may or may not work for you. The main reason I bought the 871 was for its optional built-in wireless functionality. Plus, with a flash and RAM upgrade, I can support the advanced feature set with IPS and QOS, which isn't really necessary for my home usage.
Hope this helps.
Cheers! Richard
[871] Security Features: "Hardware-accelerated 3DES for IPSec" "Hardware-accelerated AES for IPSec"
[851] Security Features:
"Hardware-accelerated Triple Data Encryption Standard (3DES) for IPSec" "Hardware-accelerated Advanced Encryption Standard (AES) for IPSec"
I believe that if you investigate further, you will find that the 83x and up have hardware encryption.
Yes it does supports 'ip helper'... It runs IOS 12.3 or 12.4 with "Advanced Security" feature set and it's only FS that it runs at 12.4 T train... It supports hw crypto for ipsec as Walter already explained... It doesn't supports Cisco DMVPN feature in the hub or even spoke role...
B.R. Igor
Thanks for your replies, I currently have a hub and poke config in some remote sites. I am not a cisco guru but i simply played around with the access-lists to do this. I believe there is a new type of vpn, probably DMVPN. Can i set up a spoke and hub without dmvpn? i probably need another lne with static ips just to play around with this. I have a pix firewall in the office and the remotes connect to a remote site using a
1700 router that connects to the main office.
If your router doesn't supports DMVPN you can deploy hub and spoke (without multicast support - no routing protocols) with Cisco EasyVPN Remote and Cisco EasyVPN Server... After that you can opt do deploy IPSec Virtual interfaces (I'm unsure whether 851 supports this) and then you will have a multicast support trough IPSec tunnels, so you 'll be able to run routing protocols over this VPN...Other way for multicast enabled vpn is to use GRE encapsulation encrypted with IPSec...
The best way to start is to get your self a Cisco Security Device Manager to configure VPN's using Microsoft like wizards...
Here are some useful links: EasyVPN:
IPSec Virtual interfaces config guide:
B.R. Igor
