Cisco 1700
Jul 28, 2006 10 Replies
Jump to replies (10)
Hey all.
Ok most of you are going to hate this. We have a cisco 1700 router sitting around. I want to start learning the basics.
Can you help me get into it. I know this is not what you all want to hear. I just want to know how to start accessing it.
SO...
What is the best way to access it? Telnet or Hypterterminal?
I have the console cable and so on. I dont know the IP. I asked no on knows it. It has been sitting on the bench and our cisco guy has left so i cant ask him
How can I get into it?
If you can help i would appreciate it.
snipped-for-privacy@gmail.com
You sort of answered your own question :-)
yea i realized that. i was using telnet just now. but i cant seem to access the router. i was trying
open but i have the wrong host
pretty much is the same.........
Thanks Guys appreciate it. you will probably hear from me again.
Peace Dan
Cisco 1700 open original image
I have a cisco 1700 running IOS 12.1(8). It is running as the gateway between us and our ISP They have given me the username/password for the
1700 and I am trying to setup a deny for port 6881 in and out. But everytime i set it up it cuts our DNS. I'm at a loss. I haven't used any cisco stuff in a long time and can't seem to find out what I'm doing wrong. the command I tried was this
router(config)#access-list 110 deny tcp any any eq 6881 router(config-if)#ip access-group 110 in
and at that point our net goes down. I get cut from the telnet session i'm in and I have to reset the router. any help? I also tried:
router(config)#access-list 110 deny tcp any #.#.#.# 0.0.0.0 eq 6881 (where the # is our IP) router(config-if)#ip access-group 110 in
Please can someone help me? We are getting a flood of 6881 syn packets from a huge number of sources. At first I thought it was BitTorrent but it has been continuing for 3 days now and I have checked every machine and we have no BT clients running.
There is an implicit deny any any at the bottom of every access-list, doing it the way you are doing it you just need to add in access-list
110 allow ip any any, make sure to remove the rule then paste them both in at the same time because the allow rule must be at the bottom.
Flamer.
Oh and also, what ip address have you actually specified, why not block this traffic to all ip addresses? deny tcp any any eq 6881
Flamer.
is equivalent to
no access-list 110 access-list 110 deny tcp any any eq 6881 access-list 110 deny ip any any
What you want I imagine is
no access-list 110 access-list 110 deny tcp any any eq 6881 access-list 110 permit ip any any
