Choosing a lab router?
Jul 03, 2010 5 Replies
bod43
I am not familiar with the exam however, I would be concerned that you might be better off with an Access Point. This will very likely cost more.
Choosing a lab router? open original image
Hi all,
I'm about to start studying for the CCNA Wireless exam (640-721), can anyone recommend a good Cisco wireless router? I was thinking along the lines of the 851W?
TIA, Jason
kumail had written this in response to
: Hey buddy check this out,
providing outstanding rates as compared to memoryx.net and other sites. I bought 1GB Approved Cisco Cat 6500 & SUP 720 Memory for around $300. And i am sure you can also find your cisco lab router here. Isn't it awesome!!..=D
------------------------------------- Hey buddy check this out,
providing outstanding rates as compared to memoryx.net and other sites. I bought 1GB Approved Cisco Cat 6500 & SUP 720 Memory for around $300. Isn't it awesome!!..=D
bod43 wrote in news:7f66d8f3-b5b3-41bb-9c9e- snipped-for-privacy@d16g2000yqb.googlegroups.com:
Thanks for the advice. Not sure whether an access point is worth a purchase as I've only scimmed through the sylabus, I think a wireless router would be pretty much essential though as there is a lot of config which has to be done through IOS.
My non-wireless Cisco 837 router seems to have stopped working so I'm using an old 3Com for the time being but I'd really like to get a decent Cisco SoHo router which I can use for the exam & future studies. I've still got all my old 2600 & 2500 routers & a couple of 2950 switches from my CCNA ICND studies.
If anyone has taken the CCNA Wireless exam & can make a recommendation I'd really appreciate it?
Thanks, Jason
