Catalyst 2950 And Multicast
Mar 12, 2006 3 Replies
Jump to replies (3)
This is a new one on me. We have about 200 2950's deployed as aggregate switches on the network. I have a client on the network now that has 2 VLAN's that they are using for Multicast traffic. One VLAN accounts for about 6Mbps and the other about 40. Now that these streams are up and running on multiple video stations I can no longer do anything management related to the switches themselves without major latency. For example if I try to ping one of the management addresses of one of the 2950's I get either a timeout or about 2~3k ms response times. Users in various VLAN's on these switches are 100% operational and they are not experiencing any latency on the network, the slowness only pertains to management of the switches themselves. Further the CPUs are only at about 15%. When the 2 VLANs carrying the multicast traffic are pruned out of the trunks to the 2950's the switches respond to pings in under 1ms and ssh/telnet sessions no longer linger between character echoes. My core 6509s are unaffected. Any guesses?
Is your 2950 management (ip address) in different vlan than workstations? It could be a software bug, which software version you run in 2950?
At this point I am indeed thinking bug as I have Foundry's on this network as well that are unaffected.
To answer your question, yes, the management VLAN is 10. The 2 Multicast VLANs are 305 and 306. I have other VLANs on the switches that are just fine as well.
My current rev is 12.1(19)EA1c. Unfortunately I no longer have a login to CCO so I can't check the bug list.
Thanks!
I think you should upgrade to 12.1(22)EA7. We dont have any problems with these switches and multicast, and we are running 12.1(22)EA6.
