Cat6509 - Convert Hybrid to Native
Oct 21, 2006 6 Replies
Jump to replies (6)
Cat6509 - Convert Hybrid to Native open original image
Hi all,
for a customer I need to change the core componentents from Hybrid to native. The actual software is c6msfc2-dsv-mz.12.1.26.E2.bin and cat6000-sup2k8.7-6-7.bin Now I had the the following questions
  1. What is the aequavilent IOS software for this cat6509 ?
  2. And when I change to 12.2.xx I saw there are nor Desktop Version. So if the customer want a free of charge update what version should can I use? I need SSH, Routing (EIGRP, OSPF) Also where can I found a good guideline for the updates ?
  3. And at last, what should I attent while updating to native ?
Thanks Udo
Read this:
This is "free" software: IP W/SSH/3DES LAN ONLY (c6k222-pk9s-mz.122-18.SXD7a.bin) If you are using "operator modules", you need different software, or if you need mpls, bgp...
And its
Hi...
Thanks, this is a cool document...
Also when I like to upgrade to the 12.2 train..maybe I also need much more memory
Do sh ver in CatOS and sh ver in MSFC, and tell how much memory you have in sup and msfc.
Actual I have only the output from a show version on the msfc
=========================================================== cisco MSFC2 (R7000) processor with 114688K/16384K bytes of memory.
509K bytes of non-volatile configuration memory. 32768K bytes of Flash internal SIMM (Sector size 512K). ========================================================== Is the output from the CAT OS different ? For my understand I have only the requiered mem and the flash ?!
And also what I don't understand, what about the BOOTLDR SW ?! This is different to the installed IOS Version ? Should I also upgrade this ? ============================================================ ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1) BOOTLDR: MSFC2 Software (C6MSFC2-DSV-M), Version 12.1(22)E1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) ===========================================================
thanks
Make schrieb:
You can look this link, table 4. This says you have WS-X6K-S2-MSFC2,
128MB/128MB.
need SUP2:
.ROMMON version 7.1(1) or later
.32-MB bootflash device
.256-MB DRAM (minimum)
.Multilayer Switch Feature Card 2 (MSFC2) with 256-MB DRAM (minimum)
Then you should upgrade MSFC2 ROMMON:
And Supervisor 2 ROMMON:
begin 666 blank.gif K1TE&.#EA`@`"`( ``/___P```"'Y! $`````+ `````"``(```("A%$`.P`` ` end
So you need to upgrade SUP2 memory to 256MB and MSFC2 memory to 256MB and Flash memory to 64MB.
Native IOS doesnt have bootldr software. Its only in hybrid.
