Cat 5500 slot reservations
Jul 07, 2006 5 Replies
Jump to replies (5)
Cat 5500 slot reservations open original image
Hi all,
I bought a Cat 5500 to assist with my CCNP studies, I am new to this device so I was curious whether the chassis slots were reserved for certain modules. I just bought a WS-X5302 RSM for it and am curious whether it has to go into a certain slot, please. Thanks in advance,
Vos
IIRC, no special slot.
However, the best thing for you to do is to find out for sure for yourself. It will be on the Cisco web site. If you can't find it after a few hours ask for asistance to help find it.
I also recommend picking up a copy of Cisco Press's "Cisco LAN Switching Fundamentals".
The book delves into switching architectures, backplanes, EARL, etc. It's a good read for understanding L2 in larger chassis.
J
Vos,
Although I also bought a 5500 to help me when I took my switching test I am sure you know that the CatOS has completely been yanked from the current CCNP tests. By the way did you get an RSM with the box?
Greg
snipped-for-privacy@gmail.com wrote:
My bad I see you bought the RSM with the device.
Greg
vos wrote:
Hi all,
Ok so the RSM can go in any slot. Also my mate had that book so I will give that a look also. Thank you everyone for your help and prompt reply.
Cheers, Vos
