cannot connect to AP 1230 with IOS 12.3, works on 12.2...
Aug 13, 2006 4 Replies
Jump to replies (4)
cannot connect to AP 1230 with IOS 12.3, works on 12.2... open original image
Hello all,
I have a very simple set up - one open network, another secured with WPA-PSK.
The clients cannot associate to the AP (latest IOS). I changed to another AP with 12.2 IOS, works like a charm. Upgraded it to 12.3.8 -- same problem. (the conf for 12.2 is a bit different, SSIDs are under the interface but the upgrade process change the conf with no problems).
I than took a new AP - 1242, dumped the exact same configuration on it, works excelant. Any ideas?
Here's the config -- Thanks!!
sh run Building configuration...
Current configuration : 2914 bytes ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname Somplace ! enable secret 5 *** ! username *** privilege 15 password 7 *** ip subnet-zero ! ! aaa new-model ! ! aaa session-id common ! dot11 ssid Open vlan 1 authentication open guest-mode ! dot11 ssid Secure vlan 10 authentication open authentication key-management wpa wpa-psk ascii 7 *** ! dot11 network-map ! ! ! bridge irb ! ! interface Dot11Radio0 no ip address no ip route-cache ! encryption vlan 10 mode ciphers tkip ! ssid Open ! ssid Secure ! short-slot-time speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0 station-role root ! interface Dot11Radio0.1 encapsulation dot1Q 1 native no ip route-cache bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding bridge-group 1 spanning-disabled ! interface Dot11Radio0.10 encapsulation dot1Q 10 no ip route-cache ! interface FastEthernet0 no ip address no ip route-cache duplex auto speed auto hold-queue 160 in ! interface FastEthernet0.1 encapsulation dot1Q 1 native no ip route-cache bridge-group 1 no bridge-group 1 source-learning bridge-group 1 spanning-disabled ! interface FastEthernet0.10 encapsulation dot1Q 10 no ip route-cache ! interface BVI1 ip address a.b.c.d 255.255.252.0 no ip route-cache ! ip default-gateway a.b.c.d ip http server no ip http secure-server ip http help-path
radius source-interface BVI1 ! logging snmp-trap emergencies logging snmp-trap alerts logging snmp-trap critical logging snmp-trap errors logging snmp-trap warnings access-list 111 deny tcp any any eq 137 access-list 111 deny tcp any any eq 138 access-list 111 deny tcp any any eq 139 access-list 111 permit ip any any snmp-server community *** RW snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart snmp-server enable traps tty snmp-server enable traps entity snmp-server enable traps disassociate snmp-server enable traps deauthenticate snmp-server enable traps authenticate-fail snmp-server enable traps dot11-qos snmp-server enable traps switch-over snmp-server enable traps rogue-ap snmp-server enable traps wlan-wep snmp-server enable traps config snmp-server enable traps syslog snmp-server enable traps aaa_server cdp timer 5 cdp holdtime 255 ! control-plane ! bridge 1 route ip ! ! ! line con 0 transport preferred all transport output all line vty 0 4 password 7 ** transport preferred all transport input all transport output all line vty 5 15 transport preferred all transport input all transport output all ! end
ComputerRoom#
You may wish to investigate -
Save Interface Level Configuration Before Upgrading to Release
12.3(8)JA:
Hope this helps.
Brad Reese BradReese.Com - Cisco CraigsList Job Openings
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Technical Forums
Thanks Brad!
I did that; the configuration is correct for 12.3.8, yet the clients cannot associate...
any more ideas? It seems like a bug, but I have a hard time beliving it is one.
wrote:
bigM schrieb:
It was something like a bug in older releases. Two SSIDs on the same (Sub)interface were not supported.
It works with 12.3(2)JA6
I have IOS 12.3.8(JA) - and it is not on the same sub-interface...
Uli L> It was something like a bug in older releases.
