PEAP Configuration Woes - PEAP configuration help
Dec 19, 2005 1 Replies
PEAP Configuration Woes - PEAP configuration help open original image
I am looking for Sample configs or setup help for a WLAN using Cisco
1200 Series AP's, AP based WDS, Cisco ACS v3.2 in a Windows 2000 Active Directory Native Mode environment. We have the WLAN up and functioning but in an EAP TLS state in stead of a PEAP State. Any help is appreciated.
This link should help :-
With EAP-TLS working, all you gotta do is enable PEAP from global Authentication setup in ACS and change the settings on the client supplicant to use PEAP. With Win 2000 you can use MS-Chap v2. In a big network it will be advisable to uncheck "Validate Server Certificate" on the client.
