ACS Cisco v 3.2 insert users with txt file
Sep 10, 2007 1 Replies
ACS Cisco v 3.2 insert users with txt file open original image
Is it possible insert the users in ACS with a txt file. I found the CSUtil.exe that provide to make this, but I'm not confidenze with the syntax and the attributes. I need a small attributes for each user, like username, password, ip address and Group.
Someone can help me..???
Fabio
Have you tried to export your existing ones and see the format so you know what to do? I had a guy who used to do it for our group, but don't remember the sytnax and don't have an example. Did you check cisco? Check these links.
