Can't read or format ata flash card on 6500
Nov 30, 2006 2 Replies
Been trying to sort this one, had a scan of similar threads.
I have a 6509 running hybrid, can't read the flash from the router or switch process dir slot0: or dir disk0: can't format it either
Comes back saying Console> (enable) dir slot0: error = -69 Open device slot0 failed (device not ready)
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAL1020N8GH Hw : 5.3 Fw : 7.1(1) Fw1: 6.1(3) Sw : 7.6(3) Sw1: 7.6(3)
I've tried the card in a 7204vxr, can read it fine. Tried the card in another Sup2, same result. I can read linear cards no problem.
Looking for tricks to get this going please. Thanks.
It is disk0:, if you have SUP2. And you should have ROMMON 7.1(1) and CatOS
7.5(1). What kind of ata you have? SUP2 supports only 64MB ata. (MEM-C6K-ATA-1-64M(=))
Thanks Make,
It was running 7.6, but turns out to be a duff slot on the sup2 I had. Worked fine on another, and you can work around the requirement of it being 7.5+ by popping the battery, read the ata flash with only 6.4.
Make wrote:
