Can't map network drive via VPN connection.
Feb 18, 2006 3 Replies
I can connect to VPN using client 4.7.00.0533 fine. I can remote desktop and ping machines but I can't map a network drive. I have copied my networks host file to my PC and the problem still exists. I have tried changing the user to my user account on the domain when mapping the drive but it still doesn't work. Any ideas?
snipped-for-privacy@gmail.com schrieb:
Name resolution problem.
WINS Server... default Netbios name resolution does not use hosts file, but lmhosts instead.
I have tried using the lmhosts file too but it still won't work. Any more ideas?
see Cisco doc for troubleshooting tips for this problem:
