CallManager 5
Aug 13, 2005 6 Replies
Jump to replies (6)
I am having problems configuring an MGCP gateway. The router (a 1760 running
12.4.2T) keeps saying 'file not found' while trying to pull its config.
I was wondering if anyone knew how to get to the TFTP directory on the CM to see if the file actually exists. Also having the same problem with IP Communicator. Since there is no way to run the Admin setup on the CM.
Also, has anyone done a succesful upgrade from a tar file from CM4?
If anyone knows of a way to get root access to the box, it would be much appreciated.
Jonathan
Hi Jonathan,
You may wish to investigate the online Cisco Voice TAC Case Collection / Knowledge Base:
http://129.41.16.73/voice/home Hope this helps.
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 U.S./Canada Toll Free: 877-549-2680 International: 828-277-7272 United Kingdom: 44-20-70784294
I am willing to bet serious money that Cisco does not have a single TAC case for CallManager 5.
Jonathan
Jonathan,
Cisco just issued a Security Notice for CallManager:
Sincerely,
Brad Reese
Already got it, it is part of sr7 for OS2.7
Jonathan
Make sure the gateway host name matches the name you configured in CallManager. One common error is adding "ip domain-name" to the gateway, but not having the full name in the GW name field of CCM.
So for example if you configured
my2600.foo.com in CCM, you'll need
hostname my2600 ip domain-name foo.com
Also you can find a tftppath directory on CCM, but be default it caches the xml files in memory, so you won't find them on disk. You can change this behavior under service settings.
I have checked this.
And no, I cannot get to the TFTPPath directory on CCM, it is running on a locked-down version of Linux.
Jonathan
