Bonding 2 T1's
May 18, 2005 3 Replies
Jump to replies (3)
Hello,
What's the smallest router I can safely use to use multilink PPP with 2 T1 lines?
Will a 1921 with c1700-y-mz.123-2.T9.bin running suffice, or would I have to go with something bigger, say a 2611xm?
TIA
John
What layer 2 protocol?
1921?
You mean 1721, right?
If they are point to points, you can do it pretty easily (cuz you control layer 2)... just encap ppp, and create a virtual template.
Jonathan
My bad...I meant a 1721.
Regarding Layer 2 protocols...PPP.
J> > Hello,
interface Multilink1 ip address 192.168.250.a 255.255.255.252 ppp multilink ppp multilink group 1
interface Serial0 no ip address encapsulation ppp ppp multilink ppp multilink group 1
interface Serial1 no ip address encapsulation ppp ppp multilink ppp multilink group 1
