What would you all consider to be the best training resource for the ASA's, VPN concentrators etc since I do not have one on my network to train on? CBTs? Simulators? (Or my most likely option renting a rack?)
WWalla
Have you tried PEMU? It is a PIX emulator - I believe it works in a similar way to Dynamips, in that it emulates the hardware of a PIX and allows you to run real PIX software on a Linux PC. Have a look at this link: that helps... Andrew
Read the full replyWhat would you all consider to be the best training resource for the ASA's, VPN concentrators etc since I do not have one on my network to train on? CBTs? Simulators? (Or my most likely option renting a rack?)
WWalla
Knowledgenet, CBTs both would be help..
Thanks
Andrew
On Sat, 15 Sep 2007 20:16:44 +0100, ipfocus.net wrote (in article ):
