best practice for migration of a tokenring-lan into ethernet?
Dec 27, 2005 3 Replies
hi all
a customer wants to migrate a tokenring-lan (a private c-range net) onto ethernet. On a separate eth-segment is the DHCP-server, wich acts as the DNS-srv too. The migrations should go as smoothly as possible. Due to lack of human resources the migration will last several days (maybe weeks ???)
My idea was to connect a router - configured as SR/TLB - in between. Therefor the migration can be done smootly.
unfortunately the DHCP and ARP request fail. I know. Cause of the cannonical/non-canonical format :-(
q: what is best practice to do such a migration without readressing the whole subnet? and keeping all the current services up and running? what are your experiences and suggestions?
tnx stephan
which is a real bad idea. better to wait until the people can do it and do a "big bang" change.
if it is so important than you should be planning to test this. the test resource for several migration steps probably dwarfs the amount of effort needed for 1 big change.
otherwise you risk breaking things in wierd ways without understanding how to fix them during migration.
from what i remember the various routers that supported translate bridge only supported the protocols that they didnt handle via routing. to handle translation bridging of IP you probably need a device that doesnt handle routing.
If you want "real" translation bridging - find a proper translate bridge - an old IBM one is probably the preferred way, since they were the standard everyone else was measured against.
wrong assumption - it is best to readdress.
And if you have DNS or other logical naming for services then it should be relatively straightforward.
test everything after every migration step - which implies only a few (ideally only 1) step.
translation bridge is a black art, obsolete in most networks and no longer widely used.
if you dont already know this stuff in detail - avoid it since learning by trial and error is slow and expensive.
stephen a écrit :
Not true. Cisco handles bridging routable protocols. If you really want to go that route, look at the "bridge irb" command. This will allow to bridge IP across the two networks, but does not solve the DHCP problem.
Seconded.
if your /24 is less than half full, you can always split it in two, change your DHCP scopes, wait for every one to obtain new addresses and then assign the second half to the ethernet segment.
Even then, you'll have people with hard coded mappings, printers, etc...
Expect the unexpected and make sure that management is well aware that the wheels may turn a little square for a while.
Yup.
Yup again.
