Belkin Wireless Network Access
Sep 25, 2005 1 Replies
Help!
I'm having major problems with my Belkin Wireless Network Access Point(F5D6130):
Lost wireless connection and tried the following:
Powered off/on AP Reset and Powered Off/ON AP Unable to ping the default ip in both cases. ip = 192.168.0.254
Attempted using the PING command and it fails. "Request Timed Out"
I have another PC connected to the network that I'm using to ping the AP.
Any ideas?
Thanks...
Additional info:
Your info is not enough.
> like how far the unit is from the wireless access point?? 24 inches
> Is your card installed properly. Was it working earlier? Yes.. but I'm
trying to connect to it directly with a cable. No luck.
Did you ping your own pc??? Yes. And I was able to ping Yahoo.com and
other computers on the network.
lemme know about this. If you dont understand what i am refering to then you
> are most welcome to ask more questions. Please leave me a note also on my > email.
> Sometimes, it is easy to answer if i run out of time and am unable to browse
> this newsgroup.
Hi Taishi,
You may wish to investigate the Belkin Wireless Support web page:
Sincerely,
Brad Reese BradReese.Com Cisco Repair Service Experts
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272
