AS-5,300 as voice gateway?
Nov 14, 2006 1 Replies
Phil.Schneck
You have to remove the mica modem cards and add a DSPM card(s). Then you have to purchase a per port voice license from an authorized Cisco Reseller. One thing to also note is that the AS5300 is an EOL (End of Life) product and so I caution you on this. Regards, Phil Schneck
AS-5,300 as voice gateway? open original image
Hello,
I have an AS-5,300 which has been used for modems access. I would like now to play a bit with open source PBXes and looking for a PRI gateway. Can I use this
5,300 as-is it has 4 ports PRI card and Mica modems) or do I have to add some voice card?
Thanks! __Yehavi:
Regards,
Phil Schneck
