Any other way to..
Oct 15, 2008 8 Replies
Jump to replies (8)
Any other way to.. open original image
Is there any other recommended way besides creating stubs to filter out lsa type 5 routes ( static route redistribution) from a backbone area to another?
thanks in advance.
I would think an inbound route-map on the ABR that denies metric-types 1 and
2 would do the trick.........
-ja
AFAIR external routes are not filtered within OSPF - ie you cannot stop them propagating via the OSPF database between routers. So filtering at the ABR would alter the routing table on the ABR, but not stop those type 5 external routes propagating between areas.
often the easiest way is to make sure they are not type 5 in the 1st place - Try using "passive interface" so a local route is OSPF rather than static, but prevent the source router forming an adjacency on the subnet. Or aggregate a bunch of statics at the point they get injected into OSPF using route maps.
Have a look at NSSA areas - but cannot remember if they give you much control of externals.
could you elaborate a little more on your suggestion? I have a main router in area 0 with static routes and I want to prevent them from traversing through the ABR. I need adj between all routers.
use BGP to carry the static if there are a lot of them - if not them do not worry about it
thanks Merv. Still curious about this though.
a snippet would be great.
Perhaps running two OSPF processes on the ABR and controlling via redistribution which routes are passed between area 0 and the non-0 area will work for you. Be careful not to send routes received from area 0 and passed into the non-0 area, back towards area 0.....
-ja
passive will only work for external routes from "connected" interface srouces.
you have 2 places to filter an external route from a static in OSPF directly - where it enters the OSPF domain, and when it drops out of OSPF into a routing table.
So you can stop your statics going into OSPF entrirely, or stop them getting into the routing table on other routers - but since OSPF replicates externals via the database, you would have to do that at each router.
the other way is that exernals do not cross into a stub (totally stubby area in cisco speak) or NSSA area.
So all externals within OSPF get aggregated into 1 default route if you set the area up as totally stubby or NSSA.
However - why filter like this? i have a customer network with 3k internal routes, where many are externals (and since almost all is dual routers in parallel, there are 2 copies of each external in the database).
Not much overhead for route propagation, processing or bandwidth.
OSPF design guide on the cisco site may be useful:
