add 2nd public IP on pix 501
Jun 08, 2007 1 Replies
Heya guys,
We have an Axis video server in my office. We like the video server have its own public ip. We dont want to share with our web,email, ip. Can someone show me how to config this?
The video server lan ip is 192.168.20.20. I also assigned port 100 on this ip btw.
tia
Start with
show access-group | include outside
This will show you an access-group command such as
access-group ACL_OUTSIDE_319 in interface outside
The word after the "access-group" is the name of an ACL that you will have to modify. Whatever ACL name it is, use that where I show ACL_OUTSIDE_319 below. Also, the public IP you want to use for the video server should be used where I put PUBLICIP below. (Note: the _319 is completely without meaning here: it's just an arbitrary name for the purpose of illustration.)
Now, configure the following in config terminal
static (inside,outside) PUBLICIP 192.168.20.20 netmask 255.255.255.255 access-list ACL_OUTSIDE_319 permit tcp any host PUBLICIP eq 100
If the video server uses UDP instead of TCP, change that line to udp .
I'm assuming here that you already have an access-group applied to your outside interface, as otherwise you wouldn't be able to have any incoming email and you wouldn't be able to run a web server inside. But if I'm misinterpreted, and your mail server is outside somewhere and you presently are not offering any services at all, then nothing will show up when you do the "show access-group". In that case, instead of worrying about using the same name, just use whatever meaningful name you want, such as:
access-list Out2In permit tcp any host PUBLICIP eq 100 static (inside,outside) PUBLICIP 192.168.20.20 netmask 255.255.255.255 access-grou Out2In in interface outside
Once you have made the above changes and tested it out, command
write memory
otherwise, the next time your PIX rebooted it would forget about the changes.
