2 public IP into Cisco 501
Mar 10, 2007 6 Replies
Jump to replies (6)
Hello all,
My office have a Cisco pix 501. We want to use another public ip that going to forward into this Axis video camera server. How would I go about this? Btw, i got it to work with single public IP, but Im abit perplexed when comes to setup 2 public IP in one single box. Any hints and tip would kindly appreciated.
kl
add another static with the new IP, its that simple !
Are the IP's on the same subnet as the current outside IP? How many IP address has your ISP allocated to you?
That really doesn't matter, as long as the IP's are routed towards to PIX outside, the PIX will answer for the IP, if it has a static for it and a ACL. I.e. your PIX outside IP doesnt have to be on the same subnet as the static IP, but the pix will answer for it.
HTH Martin
As I do understand and yes you are right, I must have misread the OP's post because I thought we were talking about IP address that are on different subnets via different providers. But as you have posted yes you are right the setup would be:
Your Public IP's 1.1.1.1 - 1.1.1.6 and your subnet is 255.255.255.248 and the PIX outside interface is 1.1.1.1 and .2 - .6 are usable then
static (inside,outside) 1.1.1.2 netmask 255.255.255.248 192.168.0.100
255.255.255.255
access-list outside_access_in permit tcp any host 1.1.1.2 eq whateverportaxisuses
and the 192.168.0.100 would be the internal IP of the axis server...
Sorry for the brain mishap, it is monday however :)
and in addition to this, if you have a secondary or second IP range routed to the same ethernet segment as the pix outside interface. fx sec range = 2.2.2.1 -.6 you can do this, even if your pix outside = 1.1.1.1 : static (inside,outside) 2.2.2.2 192.168.0.101 netmask 255.255.255.255 access-list outside_access_in permit tcp any host 2.2.2.2 eq whateverportaxisuses
(btw your static syntax is wrong) HTH Martin
Ah, no netmask on the public interface... Thanks...
