Wireless device cannot ping each other
Feb 20, 2006 0 Replies
Hi all, I'm a newbie at cisco router. I have a 851W that's connecting 2 wireless devices to one AP. Unfortunately, since I've successfully configured the router, my two computer that connected wirelessly cannot ping each other, but they are able to ping a computer that directly connected to the router.
Any suggestions?
Here are the running config that I tweaked a little bit after researching in this forum. Many thanks.: Current configuration : 4966 bytes ! version 12.3 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname router ! boot-start-marker boot-end-marker ! logging buffered 51200 debugging logging console critical enable secret 5 TRIPLEXXX ! username ORANGBINGUNG privilege 15 secret 5 APAAJALAH clock timezone PCTime -5 clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00 no aaa new-model ip subnet-zero no ip source-route ip dhcp excluded-address 192.168.0.1 ip dhcp excluded-address 192.168.0.7 //this is one wirelessly connected device ! ip dhcp pool sdm-pool1 import all network 192.168.0.0 255.255.255.0 dns-server 207.69.188.185 207.69.188.186 207.69.188.187 192.168.0.7 //one dns server on 192.168.0.7 (wireless) default-router 192.168.0.1 ! ! ip cef ip inspect name DEFAULT100 cuseeme //created by cisco by default ip inspect name DEFAULT100 ftp ip inspect name DEFAULT100 h323 ip inspect name DEFAULT100 icmp ip inspect name DEFAULT100 rcmd ip inspect name DEFAULT100 realaudio ip inspect name DEFAULT100 rtsp ip inspect name DEFAULT100 esmtp ip inspect name DEFAULT100 sqlnet ip inspect name DEFAULT100 streamworks ip inspect name DEFAULT100 tftp ip inspect name DEFAULT100 tcp ip inspect name DEFAULT100 udp ip inspect name DEFAULT100 vdolive ip tcp synwait-time 10 no ip bootp server ip domain name whateverthereasonis.com ip name-server 207.69.188.185 ip name-server 207.69.188.186 ip name-server 207.69.188.187 ip name-server 192.168.0.7 //DNS server ip ssh time-out 60 ip ssh authentication-retries 2 no ftp-server write-enable ! ! ! ! ! bridge irb ! ! interface FastEthernet0 no ip address no cdp enable ! interface FastEthernet1 no ip address no cdp enable ! interface FastEthernet2 no ip address no cdp enable ! interface FastEthernet3 no ip address no cdp enable ! interface FastEthernet4 description $ES_WAN$$FW_OUTSIDE$ ip address dhcp client-id FastEthernet4 hostname earthlink.net ip access-group 101 in no ip redirects no ip unreachables no ip proxy-arp ip inspect DEFAULT100 out ip nat outside ip virtual-reassembly ip route-cache flow duplex auto speed auto no cdp enable ! interface Dot11Radio0 no ip address ! encryption mode ciphers tkip ! ssid beaver authentication open authentication key-management wpa guest-mode wpa-psk ascii 7 093284028304823343 ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0 station-role root no cdp enable bridge-group 1 bridge-group 1 subscriber-loop-control //tweaked after searching answer in the forum bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source //same here no bridge-group 1 source-learning //same here no bridge-group 1 unicast-flooding //same here ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$ no ip address bridge-group 1 ! interface BVI1 description $ES_LAN$$FW_INSIDE$ ip address 192.168.0.1 255.255.255.0 ip access-group 100 in ip nat inside ip virtual-reassembly ip tcp adjust-mss 1452 ! ip classless ! ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 5 life 86400 requests 10000 ip nat inside source list 1 interface FastEthernet4 overload ! logging trap debugging access-list 1 remark INSIDE_IF=BVI1 access-list 1 remark SDM_ACL Category=2 access-list 1 permit 192.168.0.0 0.0.0.255 access-list 100 remark auto-generated by Cisco SDM Express firewall configuration access-list 100 remark SDM_ACL Category=1 access-list 100 deny ip host 255.255.255.255 any access-list 100 deny ip 127.0.0.0 0.255.255.255 any access-list 100 permit ip any any access-list 101 remark auto-generated by Cisco SDM Express firewall configuration access-list 101 remark SDM_ACL Category=1 access-list 101 permit udp host 207.69.188.186 eq domain any access-list 101 permit udp host 207.69.188.185 eq domain any access-list 101 permit udp any eq bootps any eq bootpc access-list 101 deny ip 192.168.0.0 0.0.0.255 any access-list 101 permit icmp any any echo-reply access-list 101 permit icmp any any time-exceeded access-list 101 permit icmp any any unreachable access-list 101 deny ip 10.0.0.0 0.255.255.255 any access-list 101 deny ip 172.16.0.0 0.15.255.255 any access-list 101 deny ip 192.168.0.0 0.0.255.255 any access-list 101 deny ip 127.0.0.0 0.255.255.255 any access-list 101 deny ip host 255.255.255.255 any access-list 101 deny ip any any no cdp run ! control-plane ! bridge 1 protocol ieee bridge 1 route ip banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user!^C ! line con 0 login local no modem enable transport preferred all transport output telnet line aux 0 login local transport preferred all transport output telnet line vty 0 4 privilege level 15 login local transport preferred all transport input telnet ssh transport output all ! scheduler max-task-time 5000 scheduler allocate 4000 1000 scheduler interval 500 end
